Everything posted by andybarrett1
Yes it is that one Rope is good 👍 Calm here Swanley / Llangollen
Good shout on airwash 👍 Flue is clean ...First light of season ....Unless a bird built a nest in there recently Thank you
Hi Just wondering if this hole should be there or should there be an Allen bolt in place like the othe two ?? There is a slight smoke leak! Thank you for reading And any advice
Webesto Issues Llangollen canal help ?
andybarrett1 replied to andybarrett1's topic in Boat Equipment
Update Overwater don't do call outs 😕 Andy -
Thank you -
Hi Thank you for reading Does anyone recomend anybody to look at a "Webasto Thermotop C" on LLangollen Canal (Currently moored at Swanley) Please don't sugggest Kings Lock .... Cost me enough for them to tell me they couldn't talk to it / So no they couldnt fix it . All seems to fire up and run OK ..... But heat not as used to be .... Coked up or filter issue in fuel line maybe I dont know ? Thank you for any suggestions Andy
Thanks all ....I am sorted now Slight delay in replying 🙂
Central heating small leak
andybarrett1 replied to andybarrett1's topic in Boat Building & Maintenance
I will try it ..... Sounds similar / same system Worse case is new rad 🙂 Thank you Andy -
Thank you..... Will try what you did .... Mine is a Webesto Thermotop Boiler. So similar to yours I guess.... Just wondering about it working now as not a "true" pressurised system Thank you Andy -
That's the stuff thank you. Just as an idea how many radiators / How big are they just as an idea ? If it doesn't work back to new Rads..... Nothing lost etc Thank You Andy -
Therein is the issue ....I can't physically get to it to plug from outside.....Fins etc in the way 😞 -
Hi Thank you for reading , we have seem to have developed a very small pin hole leek in one of our domestic radiators ...I have found "FLOMASTA 0647 CENTRAL HEATING LEAK SEALER" Am wondering if this is ok to try or will there be any issues when it mixes with the blue antifreeze. looking for some help / advise please Thank you Andy
Thank you
Thank you all for your messages It looks like just a PC 12v or two will do the job Up to me how I fit :-) Thank you all again Andy
Hi Thank you for reading I have a 12v Shoreline Fridge. I see on the compressor control box I can wire a fan between the " F Term" and "12v" ...It would help give a little more air movement in the somewhat confined space. Has anyone done this ...and have they any recommendations for the fan...I guess a 12v Brushless is a good start ...But also how big and how to mount etc ? Thank you again Andy
Blue Antifreeze Question
That's exactly what I did .....Kind of suggests why I can't find a leak whe I first looked .... Stupid Webesto header has a hole about half way up at the back .... just why I don't know ? Thank you all I "think" now leak is an antifreeze overfill issue .... Andy I think is an overfill issue Thank you all -
Hi. Quick question...A few weeks back I spilled some blue Antifreeze inside a wooden cupboard...I believe I got most of it out. But today the cupboard base as still damp..... There are other possible leak sources in there but I suspect the Antifreeze I lost still to be damp.... Is this possible Andy
Hi all Just looking for thoughts good or bad on these generator packs Kipor Generators Thank you Andy
Hi All Very Quick question :- We have a Victron 12/2500/230 Multiplus and a bank of 4 110aH Domestic batteries charger / Inverter All at slightly different voltage levels due to old school wiring practices :-) If I do the flick of the toggle to give them a "Forced Absorb" charge. My question is will this do an equalisation charge. or Am I better singly changing them all remotly and seperately ? Reason for asking is they will be rewired sensibly in not to distant future and would like to start off in a know state Thank you for reading Andy
cyrix-ct-230a Victron Cyrix-ct--230A Advice
Try it and see then :-) Thank you- 5 replies
- victron
- alternator
(and 1 more)
Tagged with:
Thank You They are the same alternators so .... Hopefully be OK :-) Solar still goes via the controller staight to the Domestics ? Andy- 5 replies
- victron
- alternator
(and 1 more)
Tagged with:
andybarrett1 posted a topic in Boat Building & Maintenance
Hi All Looking to install a Cyrix-ct-230A Battery Combiner (VSR) My question is .... :- I have seen many installs using just the one Alternator and Two battery banks, but non with two (I have one 70A Alternator for Starter Battery and another 70A for domestic bank) So is it possible at all. Just thinking of using my spare power from starter alernator to help keep domestics topped up in winter months :-) Thank you Andy- 5 replies
- victron
- alternator
(and 1 more)
Tagged with:
I have it in my head it was 16mm .Just looked page 39 below link ...16mm :-) Caldwells Catalogue I asked :- Hi Andy, Yes the sealing tape will work for this! It is approx. 3mm. Kind Regards, Hannah Caldwell Caldwells Windows Ltd
I just got the original tape from Caldwells . I got to do one side ..... All looks OK so far Only thing is as the tape settles I did have to nip the screws up very very slightly as i did get a little rain ingress the day after All good now :-) Andy
