Simple way is to fit a trolling valve to the gearbox, provided it will take one.
Did this on PRM500 worked a treat set engine revs then use valve as throttle.
From memory max revs about 1300.
http://www.prm-newage.com/p14-prm500
Simplest way of dealing with a 32a outlet to 16a inlet is a 32a plug ct a short length of 6mm cable to waterproof box with 16a DP MCB in the box and then a 16a socket.
You could use 16a RCBO instead of MCB if you really want a delux jobbie.
All legal and safe.
Since unlike many I dont do blame I'm blaming nothing, I just prefer 230v fridges.
The combi fault is an interesting one though as the inverter works fine and switches when it should, unfortuately I never notice when it goes off, its happened twice to my knowledge, once while we were away over xmas and the Eberspacher flattened the batteries and destroyed itself by killing its combustion motor.
Whilst this is true on our moorings we occasionally get power glitches and the charger doesn't always come back on, it appears to be OK but is doing nothing, cycle the power switch and its back on. When this happens the fridge being 230v doesn't drain the batteries, last week the charger was off for 4 days we only used 7% of our batteries it was only by chance that I looked at SG to see it reading 93....
One of the reasons I will always go 230v is that when on the moorings, which is more time than cruising its run off the shore power so no battery drain.
Most washing machines wont run on a MSW inverter.
We have a Candy 1000 on the boat which has replaced our Zanussi both work really well.
At present the Zanussi is in the cottage while the extension is being built, once that is finished it will be up for sale as we will have the room for a full size machine.
Simple answer no.Reasons once they ha been put under strain then they can work loose.
They work best in thin sheet metal
I have just had to replace 20 due to customer misuse!
Where we have to put in a secure blind fixing we use these
https://www.orbitalfasteners.co.uk/en/products/m8-x-50-blind-bolt-stainless-steel-a4-9-24mm-grip-range-bb0850a4asm?utm_medium=google_shopping&utm_source=google&utm_campaign=google_shopping&gclid=Cj0KEQjwuJu9BRDP_-HN9eXs1_UBEiQAlfW39mGGPqestbYuydDASSG85RQIv1FfIvlBarVbw9hnafoaAlQm8P8HAQ
We have a particularly noisy wake up call most summer mornings.
On our home mooring our next door neighbour is always up early on a weekday and likes his morning cigarette whilst leaning on his hatch. This is usually accompanied by the loudest of farts that you have ever heard, easily loud enough to wake the neighbourhood.
Me on the BargeWashing machine
Immersion
Battery charger
25amps for a surprisingly long time.
Nothing tripped mind you my shoreline has a 16amp K rated mcb (RCD covers 3 outlets)
OKYou just use the genset, make sure it has a big fuel tank.
Put genset on at 8am
Go to pub
Come back from pub at 8pm
Shut down genset.
You dont then have to listen to it and 12hrs a day for 2days might be enough
Or use all the daylight hours over the weekend to go boating
Put genset on at 11am
Go ti pub
Come back from pub at 11pm
Shut down genset.
