Skip to content
Leaderboard
Popular Content
Showing content with the highest reputation on 12/11/25 in all areas
  1. 7 points
    I must admit a bit of sympathy for the "idiot", as given the situation I'd probably have done something similar (as someone very "green" to boating). Something of a perfect storm really. - Likely already committed to the blind bend before any horn signal would be heard from the pair, and if he had made one the pair wouldn't have been able to do much about it either. - Nowhere sensible to get off the boat and hold it in - Likely a shallow channel to the offside, given the vegetation. - Inconveniently parked moored boats - Likely little experience of how much difference a loaded boat makes to how the water around it behaves. The main difference is I'd have been extremely apologetic about having made such of a mess of it- I'm fairly confident I would have made the mess though! Yes, with hindsight motoring on carefully would have been the right thing to do but it probably wasn't clear until it was already too late how much room there was to squeeze by- I would have made what would have seemed to be the safe (but wrong) choice and tried to get out of the way as well.
  2. 5 points
    This also lets us all know what Farage would have in mind for the BBC were he in a position to bring it down. This concern for broadcasting standards from a man who took money to shill for Putins Russia. I think people currently moaning about the BBC should understand who they are standing next to.
  3. 5 points
    It gets interesting when someone thinks they can get through a bridge between the two boats as they don't realise the butty is being towed. So many boaters today aren't aware of towing pairs and just don't know that the worse thing to do in most situations is to stop the forward propulsion, I regularly say to others keep it in forward so you have some steering.
  4. God: Noah, it's time to build another boat. Noah: Oh! OK, you’re the boss. Do you want the same again, animals, two by two? God: Actually no. We forgot the fish last time so this time this will be just for the fish. Also, build it with more than one deck. Noah: Big boat, just for fish and several levels. Got it boss! God: And another thing. Not just any fish. I want only Carp on the new boat. But every type of carp, common carp, mirror carp, all of them. Noah: So, let me get this right God... you want me to build you a "Multi storey carp ark"?
  5. 4 points
    A nice bit of pair boating, and one unhelpful idiot!
  6. A zener diode is pretty much the same as a diode, but with different chemical doping to make the reverse breakdown more stable and predictable. So it conducts in the forward direction like a normal diode. It blocks reverse voltage like a normal diode ... up until its breakdown voltage (which depends on the detail of the chemicals and physical geometry) at which point it starts to conduct in the reverse direction. It will then maintain the rated reverse breakdown voltage across the diode (within its heat dissipation capabilities). So by using a zener as a rectifier, you get the normal behaviour when things are going normally and the voltage is as expected (say 14.4v) but if there is a "load dump" event and the voltage in the stator rises too high, the zener diode will start to conduct when the reverse voltage gets to its breakdown voltage (say 35v) and thus shorting the excess energy through itself and converting it to heat. The maximum voltage is then capped at around its rated breakdown voltage (well, a bit higher due to its internal resistance etc). It's analagous to a pressure relief valve in plumbing! I think (guessing!) that historically it was difficult to make a zener diode that performed well as a high current rectifier diode AND was a zener, but things have moved on. I added my own load dump transient absorber not to protect the alternator, but to protect the 12v services that might not like 35v. My diodes should hopefully limit the voltage to about 18v, but I have never tested in anger!
  7. 4 points
    Well I watched it a couple of times and I would just say "Shit Happens", The pair were coming through a narrow bit and the private boatser tried to wait against the weir. Unfortunately he was up the ass of a moored boat and could only try his hardest to stop completely, there wasn't room to continue between the moored boats and the motor. The motor without doubt will have drawn his bows out and had Matt not been towing, which the private boater may or may not have been aware of at the time, there wouldn't have been a problem. You could even say all the moored boats on the outside of the bend were the problem.
  8. So some harmless "woke" stuff that harms nobody but outrages sensitive souls like you is encouraging the language of hate, the incitement of racist violence and abuse and the malevolent madness of Trump, Robinson and Farage? ...and they call us lefties Snowflakes... Bless!
  9. 4 points
    The oncoming boat did what I have experienced people doing repeatedly - panic due to seeing something slightly intimidating approaching, leading to under confidence, stopping/slowing down to "let you pass" and the inevitable drift into your path. I ended up ramming a boat this very week for the same reason. Half the time this happens because 1)people don't know how to use a horn 2) don't know what a horn means 3) people mooring on bridges and blind bends.
  10. Cite your sources for this "fact". Can't can you? The old fascist tactic... Tell the same lie loud enough and often enough and it becomes accepted as the truth.
  11. Yes, I'd also heard that version, but we all knew what it actually meant, didn't we? it was a clipped version of Golliwog and, like golliwog was intended to be disparaging.
  12. So you do have limits on freedom of expression then, who would have thought it? It is, after all, 'just words' much like calling for hotels full of migrants to be burned down was, in your view, 'just words'. If people wish to refer to you as a Fascist, why would you object? It would seem that in your world you actually have no right of objection to whatever anyone may wish to call you. If you personally don't find the term Chink offensive why should anyone care what someone from China,Taiwan or anywhere else in the region might think of it. It seems it is your right to call people what you want, so logically it becomes my right to call you whatever I want, is that how it works? Also as an aside, regarding the lad you were at college with, why wasn't he called 'Mo' or 'Dave' or whatever his name was? Did anyone at college call to you,"Oi! English"? Which kind of suggests that they were looking for a term of offence equivalent to what you were calling them, does it not?
  13. 3 points
    we’re discussing best options in that scenario but you seem to be making another argument out of nothing (as usual)
  14. 3 points
    Jeez.... you think its the other way around, some might ask?
  15. 3 points
    exactly, there was no real harm done, but it does help to put hands up and say “I fkd up” “how could I have done it better?”
  16. I think that you need to reconsider your definition of 'most people' to something more along the lines of 'most people who can be arsed' but like most right wingers you claim the majority with no evidence whatsoever. I could equally make the claim (also in the same fashion as you) that most people don't even give this stuff a moments thought in their everyday lives unless someone (such as you) deliberately stirs the shit. Since we apparently don't need any evidence, my view must be the majority view mustn't it? simply because I say so.
  17. 3 points
    Fair point. I'm too used to the stereotypical criticism of 'entitled historic boat owners'. It doesn't really look like entitlement to me on that side though - I'm pretty sure the oncoming boat intended to stop and wait, it was just the execution that was lacking.
  18. 3 points
    Did I read Jon57's 'entitlemen' comment differently... I assumed he ment the crew on the single boat not the crew of the pair.... 🤷‍♂️ The crew of the pair did a great job... the single boat however, didn't....
  19. 3 points
    You couldn't get a more experienced crew manning the working pair than those aboard. I know them both and they are not "Entitled."
  20. 3 points
    It was all the right words, son, but not in the right order. Anyway, the bbc now needs to do an in depth panorama on the Epstein files and the efforts to block their release. Go down fighting. Farage had nothing to say about Trumps involvement on jan 6, but gosh he’s had a lot to say about the bbc in recent days. Sort of similar to a lot of people of that ilk.
  21. I don't think I'd get too excited, you need to remember that in the US (as in the UK) the level of 'justice' you get is directly proportional to the amount of money that you have; the more money, the more 'justice', and under this current scumbag, corruption is rife. Probably, but that would be a bonus never to see his face on the screen again
  22. 2 points
    Whenever any boat takes a corner or goes through a narrow bridgehole it slows down. This is not very noticeable with a single boat, but if you are towing, it necessarily means the towline goes slack as the butty continues without slowing. Often the towline is just attached to the butty mast, and so there is little the butty steerer can do about it. In the video, they are using running blocks, so the butty steerer has some control over the towline length. But frequently trying to haul in the excess line whilst still being in a position to feed it out and tie the line off as the motor speeds up again looks to me like a sure fire way to lose some fingers!
  23. 2 points
    High fixed annual charges reduce the marginal costs of additional mileage, compared to distance based charging, including fuel taxes. This heavily penalises low use users, their contribution to road clutter, congestion, and road wear and road policing requirements are low. Conversly the lowering of the marginal costs of extra actually encourages additional driving, as a substantial portion of the driving costs have already paid for in the fixed component. Australia, and I suspect the US, have very cheap fuel, but very high annual registration charges. And by collecting it's distance component entirely by fuel taxes, means the horrendous road wear caused by those multiple trailers on their road trains are only penalised by the increased fuel consumption of the towing truck. This is a huge effective massive subsidy to it's road haulage industry. Ideally fuel taxes should only be used to fund the pollution outputs. They are just too, an imperfect proxy of the costs of providing the lane miles, (congestion relief), and carriageway strength and maintenance. This last factor is almost exclusively related to axle loading and distance travelled. So a distance and vehicle weight, and axleloading matrix, (regardless of fuel type) road user charge provides the best way of making the costs fall where they should lie. Presumably the UK already does have some form of distance road user charging, as how else do the capture electric bus roadcharges? Extending to include all vehicle types is probably simpler then coping with the exceptions such hybrid vehicles.
  24. 2 points
    I am not a long lining expert (in fact never really done it) but some observations: Firstly, AFAICS the pair are leisure cruisers like anyone else so share the same degree of responsibility towards other users. Secondly, one post suggests that they usually display a TOWING sign - why not always. It makes sense as very few other boaters will have ever encountered a long line pair before. Thirdly, I noticed that on several occasions the tow line was allowed to fall into the water, sometimes so that it was not visible to anyone. Was this common practice or should the butty steerer be keeping it a bit tighter? In the video, there was at least one occasion when coming around a bend it was not possible to see the butty nor the tow. Fourthly, I was surprised by the scale of the pull that the motor exercised over the stationary oncoming boat. Whilst it seems that the motor had slowed somewhat to pass the moored boats was it enough? Given that pull, any poorly moored boat would also have been removed from its pins! I have to admit that I suspect quite strongly that in the same situation I would have also pulled in - at the time it must have looked like a good refuge whilst the pair came along. It surely would have looked quite possible that with the reduced width it would be highly likely to collide if the oncomng boat has tried to carry straight on. On many canals it would almost certainly have caused one or both of the pair to ground on the off side and then they would also have been uncontrollable. Perhaps the best outcome would be for CaRT to add to their T&Cs a requirement to display a TOWING sign when ever this is the case. (One that can be seen at a sensible distance!) I am not sure that anyone's boating skills would have come out unscathed from a detailed forensic examinations post hoc . . .
  25. 2 points
    I've asked loads of people what LGBTQ means, but I can never get a straight answer.... Boom boom! 🤣 🤣 🤣
  26. Can you prove that most people do for either of those statements? Or is it another figment of your twisted imagination? You really are a bore!
  27. This troubles me for the reasons David sets out above. If Matty is right and boat builders have empty order books nowadays, I think this chap is more at risk of going down the tubes than you appreciate. And that means you lose everything. In your position I would get what you can by grabbing the boat now. But frankly, were it me I would not be in this position in the first place because I would NEVER have a new boat built. (Because I would not want to take this risk you are now facing.)
  28. Certainly it's time for the tail to wag the dog in a big way. We'll see what this will look like. It could also be a major domestic offensive. Frankly, I'm a little surprised that Trump gives a rat's ass who knows. He's famous as a lecher and serial sexual abuser of women. He brags about it. Would he turn down the services of a young lovely offered him by a fellow wealthy playboy just because she's a few years underage? Under no circumstances. And since when did he care about the legality, or morality, of his pleasures? Is it perhaps because it puts him in the same room as Bill Clinton? Yes, there are MAGAts clamoring for the scoop so they can pile on any Democrats that have seen the inside of Epstein's massage rooms. Maybe a few of them will be shocked, shocked I tell you, that Trump got his pecker petted too. But to the vast majority of them, Trump can do no wrong and double standards are just coffee with breakfast. The whole Epstein history is absolutely deplorable, but then, don't Trump fans revel in that description?
  29. Does your contract state that the payments you make establish your ownership of the boat up to the relevant build stage. I.e. can you prove that you own the incomplete boat in its present state? It would be normal for his steel (and other material) supplier's Ts and Cs to state that the steel remains their property, even if incorporated in a product, until it is fully paid for. So if he hasn't paid his suppliers, and he does go bust, they could claim ownership of the boat and there is f*ck all you can do about it - you would just become another unsecured creditor in respect of what you have paid to him, with little chance of getting anything like the full amount back. Equally if insolvency practitioners are appointed, they will seize everything connected to him, including any work in progress at his premises, and claim it all as assets to offset his liabilities. And your unsecured claim would come much lower down the pecking order for payment than the likes of HMRC. Even if you do eventually get your boat back or a refund of all you have paid, it will take a long time. That's why others are suggesting you take the boat away now - possession is nine tenths of the law.
  30. 2 points
    Argument about technique is moot - there is no technique needed here. Oncoming boat just needed to keep the power on and not hesitate. There is plenty of room there for them to pass each other.
  31. 2 points
    One 19mm hole through the roof shouldn't be that difficult to deal with... 😉
  32. 2 points
    Either way I suspect lots of boaters would have made the same perfectly justifiable decision -- let's keep out of the way instead of trying to pass a loaded pair in a narrow section with moored boats! -- and ended up with exactly the same problem, with no easy way out once the boat starts to get pulled out (unless you have a BT, which is obviously verboten...). I've seen far more stupid boater behaviour on many occasions which *does* deserve the kind of comments some posters are making about this... 😉
  33. 2 points
    I would always aim to keep the cable between the antenna to the absolute minimum, ideally no more than 1 metre, at a push 3 metres. That way you might actually get some gain rather than just covering cable losses. My Poynting antenna has the standard 5 meter cables on it and in reality there is very little difference between that and paddle antennas on the router. However the router is not in a metal box. LDF 450 was a good cable to use at GHz frequencies 😉
  34. 2 points
    Just tick the "Don't know" option if you're not sure ... 🤣
  35. So would you draw the line anywhere?Is it OK to call people 'n*ggers', p*kis, k*kes, would you draw any lines anywhere? If not is it OK to call you a Fascist since, after all it is 'only a word'.
  36. 2 points
    I don’t think he could have stepped off, as it looks like there was some sort of barrier out from the concrete edge/path maybe some sort of bywash/run off, which can be seen in the opening post. Just a case of inexperience, probably never met a pair of boats on a long tow before on a bend with moored boats, as the butty guy said if he just kept going he would have been ok. The Narrowboater probably thought he wouldn’t have got through without scraping boats. Just put it down to experience and learn from it. We all started once and we’ve all made mistakes and still do.
  37. 2 points
    A recommended 4x4 MIMO 5G router, about £300: https://www.gl-inet.com/products/gl-x3000/ A suitable antenna can be found here: https://3grouterstore.co.uk/product-category/5g-antennas/4x4-mimo-5g-antennas/ (general comment : bigger antenna from a reputable supplier (e.g. Poynting, Panorama) = better performance but also higher cost)
  38. 2 points
    What are they supposed to have apologised for? They were going along in a safe and considerate way, slow past moored boats in a narrow bit and so with very little steerage way on the butty. The other boat wedged itself across their path and through the middle of the pair through sheer incompetence and despite their best efforts to avoid it. There's a cheery 'morning' at the end.
  39. Also just finished watching it and a very well made documentary it was. He wasn't someone espousing his version of what happened, he simply supplied the known facts but qualified it by saying that it can never be said for certain exactly how the ship came to grief. I was also massively impressed with the bravery of the captain of the SS Arthur M.Anderson who having just seen an almost identical ship to his own disappear off the radar, when asked by the Coastguard to turn back into the storm to search for the boat, then did so because his view was 'that was what the crew of the Edmund Fitzgerald would have done for him' had the situation been reversed.
  40. That's because their cooling tanks are too small - typically sized to be adequate at canal cruising speeds, but not when punching currents or tides on rivers - not a fundamental issue of the type of cooling.
  41. So there it is. A hyped up atticle about a terrible council wasting money because something they invested loads in is unused, with a tiny bit at the end that says they aren't being used because they aren't finished yet. Sheer stupidity masquerading as reportage, with a bit of help from the Reform Party (per Facebook) and Alan.
  42. 1 point
    I work in Runcorn, well Weston Point, and never going to be the most glamorous holiday destination. However the canal arm is inoffensive and at 5miles long its an easy 'silver propellor' location to tick off. Outside the The Brindley theatre or opposite the moorings right at the end is only 500yrd difference. I've not stopped the night at either but I cant see you have any bother. There is a public carpark too, and the new Mersey bridge has reduced the traffic.
  43. 1 point
    Skip past me droning on to see how i mounted this.... you might find it useful?
  44. I think you need to wake up and smell the coffee. Most people dislike this ludicrous woke stuff like calling expectant Mums "pregnant people". Rightly they wonder just how far it's all gong to go because the trend is inescapable. They want out of it, and at that's one of the reasons that right wing parties are in the ascendancy.
  45. No, I haven't voted either, for precisely this reason. Whilst this source (https://www.understandinganimalresearch.org.uk/news/animal-research-statistics-for-great-britain-2023) will obviously have a bias towards testing, it is helpful to try to establish the scale and methods that are used. To start with the 40.9% that is referred to as 'sub threshold' which basically means that the sole cause of pain to the animal will be the injection, if we don't like that, then we'd best not take our pets to the vet since that happens on a daily basis. Then we have the 38.2% referred to as 'mild' which means both an injection and an additional procedure such as taking a blood sample. Once again, vets do this on a daily basis. So that now accounts for 79.1% of all testing, should they all be banned? The remaining 20.1% is where things become more problematic. For the 'moderate' and 'severe' experiments I would prefer that other methods, if available, were used. As far as 'non-recovery' goes, well unless you are a vegetarian you cannot really criticise since there is almost no difference between anesthetizing an animal and then killing it for food or anesthetizing an animal and then killing it, without recovery, after research. So for me the answer is 'No'....and 'Yes'. As the linked article indicates, a lot of research that used to be done on animals is now carried out on cell cultures, computational models and human studies. It has also been found that some animal results don't translate to humans anyway. If they'd carried out testing on dogs for chocolate, we simply wouldn't have any
  46. "Chris Deuchar offers a personal tribute to John Forth, who died on 10th March, following a short illness" from May2008 WaterwaysWorld " John Forth and I started what others have said was an 'unlikely' friendship nearly 30 years ago. Forewarned about a couple who had hired a boat, and then caught what is generally known as the 'canal bug', John's entry into the Navigation Inn at Shardlow meant that I knew instantly who he was. I also knew then that we would become firm friends. If you are unsure whether you have ever met John, then you have not. He was one of that select band of people who would forever keep a foothold in your brain. Of course, not everyone saw the same thing in him, but they missed out on a man of great honour and loyalty to his friends. He was hard working, intelligent, well educated and endlessly thoughtful. From his beginnings as a hire boater through historic boater, he progressed to become a canal carrier We spent innumerable evenings together putting the world to rights by discussing all sorts of things from details of boat design, dredging plant. steel fabrication jobs, woodwork and, of course, boating. A lot of the latter subject naturally related to British Waterways' management and its idiosyncracies. John once said that he kept carrying not because of BW but despite them! John's indefatigable wife of some 40 years, Madeleine, has kept their very successful coal business running throughout John's illness. They had one of the longest surviving, and certainly the best, canal retail coal businesses in terms of tonnage carried. Indeed, they have possibly carried more over the last twenty-four years than all the other waterbome vendors put together. Hopefully Maddy will continue the business: she is such a great organiser that I know she can succeed. Despite John's larger than life character, they just got on with the job, and generally stayed away from the glare of publicity. They actively avoided boat rallies, TV appearances and other media attention - with the exception of brief scenes and a single programme for Japanese TV! John was someone who enjoyed life, and lived it to the full. Unlike many people, he was determined to realise his dreams - even if he had to grab them by the throat and wrestle them to the floor. On 20th March, John's coffin was carried on his boat Newdigate through two locks from the Two Boats Inn at Long Itchington, to the Blue Lias Inn. From there it was taken on the back of his decorated coal lorry to Banbury Crematorium for a special service to celebrate his life. His final journey was accompanied by nearly 200 mourners at various stages, twice the number allowed by health and safety regulations inside the crematorium - I can only imagine John's thoughts on that piece of officialdom! The service was followed by a long wake back in the Blue Lias. If John has gone to heaven, then I know he will be giving them hell. If he has gone to another place, then he is sure to have worked out a good deal. He was probably my best mate, ever, and I shall miss him terribly. " Hopefully WW / ChrisDeuchar will be content with reprinting (and Robin Smithett for the picture).
  47. 1 point
    "The BBC" and "The Panorama team" are not the same thing... They shouldn't have made that edit, but the blame lies with the team who made the programme -- it's extremely unlikely that the executives who resigned ever saw the footage or approved it before broadcast. But they've resigned anyway to try and stop the endless relentless pillorying of the BBC by the likes of the Torygraph, and certain posters on CWDF... 😞 https://www.theguardian.com/media/live/2025/nov/10/bbc-tim-davie-resigns-bias-panorama-donald-trump-latest-news-updates "I’m very sad about Tim Davie stepping down. I think he was an effective leader at the BBC. I think he was a great champion for public service media, but there is no escaping the fact that he was very slow to act on this particular issue. But this isn’t the first time and on this particular issue, Michael Prescott’s report, he just didn’t take it seriously until it was too late. He should have reacted with concern and examined the claims, but just ignored it. But you know, I do feel it was entirely avoidable and it’s really regretful given the huge commitment to the BBC and public service that Tim Davie demonstrated."
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
