The problem with LA batteries is not just the charging time, it's the absorption time needed to get them up to 100% SOC and hold them there, which is needed to avoid sulphation.
The Leoch PLC batteries (batterystore.co.uk are the cheapest UK source, are partnered with Leoch) have more data available under other labels they're sold under such as Outback (Australian). If you dig into their data sheets, maximum recommended charge current is 0.25C, with about 4h absorption time at 100% SOC. But they are sealed. However this is little real-world experience of them in boat applications because they're relatively new, and they fall into the same "neither fish nor fowl" problem as advanced AGM/cell cells -- they're a lot more expensive than traction cells (about 2x the cost) and still have a lot of the LA disadvantages, and if you're going to pay this much you might as well pay even more and use LiFePO4 and get huge benefits (fast charging, higher efficiency, no absorption to speak of)
Traction cells (Tayna cheapest, or pbbatterysolutions?) are designed to be charged back to 100% overnight (>8h charging time) every night, and have similar maximum charge rates and if anything even longer absorption time. This is because they are very tall (typically a couple of feet) and rely on gassing at full charge to circulate the acid, and even then this takes a long time to equalise concentration over the full height. Which also means they *have* to be taken to the bubbling stage regularly to avoid sulphation, which is why fan extraction/venting is needed to prevent building up of explosive gases. Then you almost certainly need an automatic watering system to keep them topped up, which adds to the cost.
Having said this, if you do all this (and can put up with the long charging/equalisation times) they're relatively cheap and do last a long time -- when I spoke to Hybrid Marine they said they've got boats out there (all parallel hybrids) after 8-10 years still on their original set of batteries, though obviously without knowing how much they've been used you need to take this with a pinch of salt.
https://www.hybrid-marine.co.uk/index.php/products/narrowboat
Here's a source for BEV battery packs, much cheaper than new but still pretty expensive.
https://www.secondlife-evbatteries.com/collections/ev-battery/Module
Bear in mind that these are almost all Li-ion, which need *extreme* care with charging/discharging/protection because if things go wrong the consequences can be catastrophic (battery fires), and there may be consequences for boat insurance because of this -- an issue not often mentioned but I think everyone knows what insurance companies are like, if you don't tell them about the batteries they'll probably refuse any claim. I don't know if the companies who cover UK canals have much experience of Li-ion, but lumpy water companies do and they're very wary of them, especially with home-brewed BMS. I suspect this is the reason why none of the reputable builders of electric boats in the UK have gone down this route, they all use LiFePO4 (the ones who do a "proper job" i.e. an expensive one) -- the cheapskates use LA cells (PLC or traction) with all their disadvantages.
The real problem with LA in an electric boat/hybrid where charging is usually from a generator is the long charging/equalisation times -- depending on charging rates, generator run time is at least 2x what you'd predict by dividing required charge by maximum charge rate (can easily be as much as 3x, especially allowing for round-trip energy losses), and for a large part of this time the batteries aren't accepting much current (and it's tailing off) so the generator is running well below full power, bad for efficiency -- as well as wasting fuel, long run times mean servicing is needed a lot more often. You also have to pay close attention to your battery charging regime, making sure to fully charge to 100% SOC and equalise regularly.
In comparison LiFePO4 can just be treated as a power bank -- so long as you don't overcharge or overdischarge them (which is why a proper BMS is needed) they don't really care much what SoC they're at, have much higher round-trip efficiency, and need next to no equalisation or care and attention. The biggest bonus is having to run the generator for much shorter times than LA, which is pretty much the entire point of going electric/series hybrid in the first place.
Unfortunately they do cost more ?
