Something they could legally do - make all moorings 24 or 48 hours. Plenty of time for 'visitors' to have a look around, and then move onto the next attraction.
4
points
If they cannot legally refuse boats access to the city (refuse to licence) then a simple remedy would be to make being there as unpleasant as possible.
Remove all water points.
Strictly enforce stopping times.
Ban 'breasting up' as causing a potential restriction to navigation.
They could do a lot of things if they were really motivated to, but undertaking an 'exercise' cum consultation to get boaters to come up with suggestions absolves them of responsibility if they implement unpopular actions. "We only did what boaters themselves suggested".
If no actions are the result then they can say "we asked, we tried, we couldn't come up with any legal means of restricting boats in London".
4
points
I've moved lots, of both, and on narrow, shallow canals, narrowboats move far easier than widebeams, even of a 10 foot width.
There is a couple now living happily on a narrowboat who had the worst 18 months of their lives on a 9ft Wincham (Collingwood shell) widebeam launched on the K&A and came to the GU.
Why when so many brokers cant get enough narrowboats are record numbers of widebeams on Apallingduck??
On wide rivers, there is no doubt that widebeams make sense for liveaboards that dont want to go too far afield and want luxury, but to enjoy Englands waterways, narrow is the answer.
3
points
Also bear in mind that a lot of people commenting on widebeams have very little or absolutely no first hand experience of them.
I've been living on a bog standard 57 x12ft Liverpool Boats NB-style widebeam for the past 15 years. I've also punched Thames on red board from Laleham to Reading in 2 days by myself. Been up and down the tidal Thames between teddington and limehouse a couple of times including going downstream & the difficult turn into limehouse. Been all the way from Reading to Bristol on the K&A without a problem, done parts of the river Severn. Crossed the Bristol channel from from Bristol via portishead to sharpness, the warks Avon, etc, etc. I've moved my widebeam more than most narrowboaters that I know.
My boat may seem unwieldy to the inexperienced but I can assure you it isn't. It steers and swims very well and that was also the opinion of one of the Gloucester pilots and also the opinion an active and respected forum member who's steered it on a couple of occasions. Unwieldy is all relative anyway. A 60ft narrowboat may seem unwieldy compared to a 20ft grp cruiser.
So bear in mind that some narrow boaters like to put down widebeams even though most don't really know what they're talking about.
3
points
I think the opposite would happen, once the landlord realises that you can drink several pints he turns the current down so that you have to stay there longer.
A couple of years ago we and Goliath spent some time on a pub mooring. After a few days the landlord knocked on the boat and asked how much longer we planned to stay. I was expecting a telling off and sling yer hook warning, but he said "if you plan to stay much longer i'm going to order in an extra barrel".
...............Dave
2
points
I'm not going to say what I think about your reply because it'll get me banned.
2
points
Dunno about that, I'm only 63 so If I really cut down on the drinking I might just make it. ?.
2
points
We have a Sydney onboard. He loves being on the boat and around water in general but does fall in on a regular basis. Fortunately he is bright enough to swim to the back of the boat where we can scoop him out, and his legs are not long enough to go anywhere near the props!!
He is a bit of a speed freak and prefers it when the boat is going fast.
2
points
No assistance at the tunnel, they book you in and out, plus one chap opens and closes the door and switches fans on and off. Foxton and Watford both book you in and watch what you do.. Even if they just had the same opening hours as they do now without the booking. Boaters have always accepted if there are too many boats for a convoy they have to wait. When I came through there were just as many boats queuing, 6 one way and 5 the other.
point
Good idea and maybe we could make lager drinkers pay double what a beer drinker pays?
point
Hi,
I had a similar problem with my OD4, and it developed a pinprick hole in the base, A complete overhaul was needed, a new burner pot was sourced. Kabola says the pot can be removed via the top. that's cobblers, the best way is to remove the fire as the burner pot will only come out from the bottom. It's fairly easy to remove the fire, 2 bolts secure the drip tray from the black round cover. I have attached some pictures showing the burner pot and holes.
I will attach some pictures showing the operation later, a year ago I fitted a new carb. spares for the burner pot and a new mica glass cost about £300, this also included a new cage, carb was £200 on top of that, but I ended up with a virtually new heater.
My fire also provides hot water.
point
The Screwfix drill bits break well before their breaking point, that's why they sell them in packs of ten ?
...................Dave
point
Actually it *is* obvious that central generation of electricity and BEV are more efficient than diesel IC engines, the "well-to-wheel" efficiency is about double -- so even if the power comes from fossil fuel sources this is a good thing (about half the CO2 emissions), if it comes from renewables than obviously much better.
People don't *want* to change because vehicles (and boats) powered by fossil fuels are cheap, powerful, quick and easy to refill, and don't have range limits. Unfortunately this attitude is what is screwing the planet up (not just transport) so we *have* to change, and cars (and boats) are an obvious target because they're a big culprit. People will just have to put up with the disadvantages (which are rapidly getting smaller) as a price to save the planet. Now for things like stopping green beans being airfreighted from Chile... ?
Anyone who sees change like this as going backwards needs to wake up and look at the consequences of carrying on as we are... ?
point
If you are aware of the travel limitations of a 'fatty' and can 'live with them' then there is absolutely no question "GO -FAT"
Comfort and space will be much. much greater than you could imagine. The difference between 6' 10" and 12 foot is huge. You can now get two rooms side by side (ie Kitchen & dining room) instead of being 'in tandem' ) one behind the other like train carriages. Like 'living in a 6' sewer tube'.
I have had both 'narrow' and 'fatty' boats (current boat is 14 foot beam) and given the choice 'fat' wins every time for comfort, 'anorexic' wins every time for use on the narrow canals.
With a 'fatty' you can always have (say) 1 year down South, & when you get to around Birmingham, have her lifted out moved a few miles North and dropped back in then you can have another year doing the Northern waterways.
point
