Here is another arrow to add to your quiver :
The opening paragraph to C&RTs T&Cs states :-
Numbered paragraphs below are legally binding general conditions. If you breach any of these, we are entitled to terminate your Licence and you could face legal action, which may result in the removal of your boat from our waterways.
The following is an UN-NUMBERED paragraph so presumably C&RT accept that it is not legally binding.
A HOME MOORING
The boat must have a home mooring (as defined in the Licence Terms and Conditions) - somewhere you can lawfully leave your boat when it is not being used for cruising.
Moorings are provided by a wide choice of boatyards and boat clubs, as well as by Canal & River Trust - www.canalrivertrust.org.uk/boating provides a moorings search facility that includes these moorings. It also includes helpful information about getting started with boating on inland waterways.
The only exceptions to the requirement to have a home mooring are:
If the boat is removed from the water when it is not being used for cruising.
The boat navigates without staying in any one place for more than fourteen days (or less where local signs indicate a shorter period). Please read our Guidance for Boaters without a Home Mooring below.
CRT new T&C proposal at 3.1: You must cruise on the waterways whilst you are away from the home mooring (save for any period when you leave the waterways or when the boat is lawfully moored at another mooring site).
The 1995 Act actually states : ‘(i) the Board is satisfied that a mooring or other place where the vessel can reasonably be kept and may lawfully be left will be available for the vessel, whether on an inland waterway or elsewhere’.
No mention of CRUISING in the 1995 Act - a small but significant change.
C&RT then go onto explain that when away from your home mooring you cannot remain in one place for more than 14 days.
So a boat with a home mooring, but away from its mooring, cannot stay in any one place exactly as laid out in the Guidelines for Boaters without a Home Mooring.
So - lets look at the guidance for Boaters without a Home Mooring - which co-incidently, is yet again an UN-NUMBERED paragraph so is not legally binding.
GUIDANCE FOR BOATERS WITHOUT A HOME MOORING
The law requires that the boat “will be bona fide used for navigation throughout the period of [the licence]”.
The terms ‘cruise’ and ‘cruising’ are used in this guidance to mean using a boat bona fide for navigation.
“Place”
The law requires that stops during such cruising should not be “in any one place for more than 14 days”. “Place” in this context means a neighbourhood or locality, NOT simply a particular mooring site or position.
Therefore to remain in the same neighbourhood for more than 14 days is not permitted
So to summarise (again) a boat WITH a home mooring, when away from his mooring must NOT remain in the same neighbourhood / place / locality for more than 14 days.
A very clever person used to trying to hide restrictive Terms & Conditions in a document has prepared this document and worked on he assumption that a 'lay person' will not take the trouble to follow the involved, interwoven thread of restrictions from one set of licensing conditions to another.
