Narrowboat gangplank
  • Please log in to reply
17 replies to this topic
#1 Workhorse
Workhorse
  • Members
  • PipPipPipPipPip
  • 84 posts
  • Boat Name:Out of Sight
Posted 04 March 2007 - 11:33 AM
Can anyone give me any idea's as to the timber that should be used to make a new gangplank for my narrowbaot.
What I don't want is to get the plank all finished and looking good and then for the thing to twist. The plank should also be as light as possible.
The size i'm looking at is: 275cm long x 22.5 wide x 4.5 depth.
Any idea's?
  • 0
#2 carlt
carlt
    Long Standing Member
  • Members
  • PipPipPipPipPip
  • 21,307 posts
  • Gender:Not Telling
Posted 04 March 2007 - 11:39 AM
Any idea's?
Try a length of scaffold board. They're mid quality larch that's not allowed to move (health and safety and all that), about the right dimensions (though I can't be bothered translating your fancy-dan foreign measurements) and about 11 quid for a 13 foot long one.
  • 0
#3 Supermalc
Supermalc
  • Members
  • PipPipPipPipPip
  • 2,542 posts
  • Boat Name:Wud-E-Nuff
Posted 04 March 2007 - 11:47 AM
I made mine from the pine offcuts. They're a bit springy, but not too heavy and strong enough to walk on. I painted and sanded the top.
It's on the roof......dozens of photos, but about the best I can find.
Posted Image
  • 0
#4 catweasel
catweasel
  • Members
  • PipPipPipPipPip
  • 11,096 posts
  • Gender:Male
Posted 04 March 2007 - 12:35 PM
Any idea's?
I made two boarding planks from mahogany. One stayed really flat, whilst the other could be used for a prop on a biplane.
For us luddites that is about 108 ins X 9 ins X 1 3/4ins
Funny that I can work in metric all day, but have never been able to visualise in metric.
  • 0
“In the practice of tolerance, one's enemy is the best teacher.”
http://destinynarrowboat.weebly.com/
http://www.shangitbooks.com
#5 Workhorse
Workhorse
  • Members
  • PipPipPipPipPip
  • 84 posts
Posted 04 March 2007 - 12:36 PM
Thanks for the info. In future i'll cut out the fancy figures. Stick to the good old imperial.
  • 0
#6 Keeping Up
Keeping Up
  • Members
  • PipPipPipPipPip
  • 11,294 posts
  • Gender:Male
  • Boat Name:Keeping Up
Posted 04 March 2007 - 12:44 PM
Gangplanks are always a bit heavy, especially the scaffold plank ones. If you want a lightweight version, have you thought about one based on a length of aluminium ladder and a sheet of ply. You can buy them complete (but quite expensive) or make one from a scrap length of old ladder yourself. The wood can be quite thin because it rests on every step.
  • 0
Allan
Visit the Keeping-Up website to see where we've been
#7 David Schweizer
David Schweizer
  • Members
  • PipPipPipPipPip
  • 9,150 posts
  • Gender:Male
Posted 04 March 2007 - 12:48 PM
If you are any where near a major construction project nearing completion, they may have some of the reduced length scaffold boards, and you may be able to buy one cheap. When they were finishing the restoration work on Avoncliffe aqueduct a few years ago, there were about twenty shortened boards which the scaffolding hirers would not take back. The contractor did a brisk trade in shortened boards for the price of a pint each, that's how I got mine.
  • 0
#8 Supermalc
Supermalc
  • Members
  • PipPipPipPipPip
  • 2,542 posts
Posted 04 March 2007 - 01:00 PM
I'll tell you what would make a good lightweight gangplank.....car trailer ramps. One made from ally, not steel of course.
A piece of checkerplate with the sides folded to make a box section. No welding required because if the seam is below the top plate they will only ever be stood on from above.
Not sure of the cost of this. I was given half a sheet by the chap who made a floor for his Norman 20. When the boat was sold last year it has been taken out again.
  • 0
#9 Pie Eater
Pie Eater
  • Members
  • PipPipPipPipPip
  • 1,105 posts
  • Gender:Male
  • Boat Name:Coccium
Posted 04 March 2007 - 03:59 PM
We fished our gangplank out of the Caldon Canal a couple of years ago. It is a scaffold plank and there were loads that had been thrown into the canal off a building site. The plank has metal protectors on each corner and painted up it looks ok even though it is not used much.
Steve
  • 0
Owe everybody and die happy.
#10 Workhorse
Workhorse
  • Members
  • PipPipPipPipPip
  • 84 posts
Posted 04 March 2007 - 05:34 PM
Steve
Thanks for the info. I seems that scaffolod poles are the more common thing to use as a gangplank. Mind you, how do they paint up, or is it a matter of rubbing down first?
  • 0
#11 Alec Gatherer
Alec Gatherer
  • Members
  • PipPipPipPipPip
  • 393 posts
  • Boat Name:Currently without.
Posted 04 March 2007 - 05:40 PM
Can I come and watch the first time you use a scaffold pole as a gangplank?
  • 0
Space is dangerous.
#12 carlt
carlt
  • Members
  • PipPipPipPipPip
  • 21,307 posts
Posted 04 March 2007 - 05:45 PM
They sand down alright (though I've got a planer/thicknesser so that saves time), planks that is,not poles, then primer and then fourteen coats of your finest marine paint, rubbed down with flour paper between each coat.
Or a couple of coats of dulux gloss works for me (other gloss paints are available).
  • 0
#13 TeeELL
TeeELL
  • Members
  • PipPipPipPipPip
  • 581 posts
  • Gender:Male
  • Boat Name:Elemiah
Posted 04 March 2007 - 06:05 PM
I found a discarded scaffold plank which had cracked - nevertheless, the remaining pieces were of sufficient length to suit, a bit of work with the belt sander and a dollop of paint and 'job done'.
  • 0
Tony[font=Arial][size=2]
#14 Workhorse
Workhorse
  • Members
  • PipPipPipPipPip
  • 84 posts
Posted 04 March 2007 - 07:20 PM
Why should you wish to come and watch?
Edited by Workhorse, 04 March 2007 - 07:21 PM.
  • 0
#15 kawaton
kawaton
  • Members
  • PipPipPipPipPip
  • 231 posts
Posted 04 March 2007 - 08:08 PM
Because no doubt you'd fall in.....unless you are skilled gymnast
  • 0
#16 carlt
carlt
  • Members
  • PipPipPipPipPip
  • 21,307 posts
Posted 04 March 2007 - 08:56 PM
Welcome to the pleasuredome workhorse. One slip of the fingers and they're on you like hyenas on a rotting carcass.
:rolleyes: :angry:
  • 0
#17 Workhorse
Workhorse
  • Members
  • PipPipPipPipPip
  • 84 posts
Posted 04 March 2007 - 10:42 PM
How did you guess?
:rolleyes: :angry:
Thanks for the warning. Friend or foe?
Edited by Workhorse, 04 March 2007 - 10:41 PM.
  • 0
#18 DHutch
DHutch
  • Site Owner
  • 14,425 posts
  • Gender:Male
  • Boat Name:EmilyAnne, Dutch-barge-style SteamNarrowboat.
Posted 05 March 2007 - 01:40 AM
We had an ok plank, that went the way of all wood, then a bit of scaff board for a bit, out of the cut, but it wasnt upto much, and then a 10ft lenght of oak (also out the cut), which was great for walking, but heavy as you like for lifting.
- Then (long story) we ended up with a alumium based one, simuar to the boarded over ladder idea.
- I guess its ok, but its huge, takes up loads of deckspace, is still quite heavy, and just massivly overkill.
Oneday we will have the perfect board... Proberbly just a good grade of softwood. Maybe some douglas...
Daniel
Emilyanne - Small website about our boat.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
