rbateman Posted May 22, 2013 Report Posted May 22, 2013 Hi all, I'm just about to purchase two of these solar panels and was wondering whether anyone had any experience with mounting something similar on their roof and was able to recommend where best to get screw-down / secure mounts? I had a search through old posts and, while many discuss various options for securing solar panels or discuss building their own frames, no-one seems to have mentioned actually purchasing frames from a given site and how they found the experience of installing it (unless I missed a post somewhere). Thanks as ever for any thoughts or experience. Ryan
DeanS Posted May 23, 2013 Report Posted May 23, 2013 Hi all, I'm just about to purchase two of these solar panels and was wondering whether anyone had any experience with mounting something similar on their roof and was able to recommend where best to get screw-down / secure mounts? I had a search through old posts and, while many discuss various options for securing solar panels or discuss building their own frames, no-one seems to have mentioned actually purchasing frames from a given site and how they found the experience of installing it (unless I missed a post somewhere). Thanks as ever for any thoughts or experience. Ryan Not really a proper answer, but I would imagine that if you buy any sort of mount, you'll need to screw them into your boat roof. I have always thought that is something no one should ever contemplate, as it does leave room for leaking etc later on. Just a thought Many have top boxes, with solar panels as the tilted box roofs....if you search my recent threads, their was one about installing panels..... I too havent seen an actual mount supplied by solar suppliers.
dor Posted May 23, 2013 Report Posted May 23, 2013 (edited) I bought similar panels from Midsummer Sun, who also supplied mounting brackets. The brackets are basically just bits of alloy angle - quite thick though. I'll tr and find a picture. ETA pics The brackets are fixed flat with tamperproof screws to reduce chance of them being lifted. Note brackets on the front corners to stop centre rope getting caught underneath. Edited May 23, 2013 by dor
Mat B Posted May 23, 2013 Report Posted May 23, 2013 I am a fan of magnets: Saves any drilling or welding. (Plus a padlock and chain for security) Ebay link m@
FidoDido Posted May 23, 2013 Report Posted May 23, 2013 (edited) I bought magnets too.. http://e-magnetsuk.com/magnet_products/clamping_magnets/car_roof_top_magnets.aspx These guys do a range of mounting products http://www.trueshopping.co.uk/catalog/Mounting_Brackets/5580.html I went for some simple angle shelving brackets from B+Q for £4, and drilled them for the magnets and for the panel (which hasnt got here yet).. Edited May 23, 2013 by FidoDido
BlueStringPudding Posted May 23, 2013 Report Posted May 23, 2013 Mine's on little adjustable furniture legs from Homebase to lift it above the roof. Then there's a chain passing through hoes drilled in the panel frame and through the holes of a flying-saucer vent on the roof, under the centre of the panel. Plus a couple of heavy duty bike locks through the sides of the panel frame round the roof rails. Gives enough room for manoeuvre to tilt the panel slightly if I want to, but pretty secure.
Grace and Favour Posted May 23, 2013 Report Posted May 23, 2013 We had stainless steel brackets fabricated, allowing plenty of air beneath the panels. We've bolted them to the panel frames using security bolts, and bolted them to the roof using the same security bolts into 8mm Rivnuts, (with neoprene gaskets).
Cashflow Posted May 24, 2013 Report Posted May 24, 2013 or even : http://www.ebay.co.uk/itm/330858328323?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_2142wt_1161 16 brackets enough for 4 panels. I have just bought a load just hopeing theyare high enough for the panel to clear the roof ! Cheers Andy
