Hi All
I have found a different server thatr doesent but you with adverts.
I have it facing Ely ATM but will move it as the sun moves around. Sadly theres not a lot going on ATM but a boat will come past sooner of later.
The feed is here
http://vaughnlive.tv/boatcam or Linky if you prefer.
Comments welcom on viewing and systems being used.
Biggles (Kevin)
Hi All
The feed is here
Biggles (Kevin)
Great picture quality Kevin,I can only tell it's live because the willow is moving in the wind.!!
I've missed most of your last weeks efforts after only being on mobile internet, what cam and software are you using?
Its on again now. I needed the PC for mor important work.
Hi Kevin,
It's a good quality picture. I would be interested to know the technology behind it.
For example:
Is it over a WiFi link or 3G/Dongle internet connection ?
Is it 240 V (or Shoreline) dependant, or running off the batteries ?
How much was the web camera ?
Obviously, interested in the validity of a remote viewing security solution - it would be nice to 'check-in' on the boat over the Internet when not on board ! :-)
Many Thanks
Kind Regards
Mark
  • 1 month later...
Hi Kevin,
For example:
Many Thanks
Kind Regards
Mark
Its a Microsoft HD webccam through a laptop streaming to Vaughn. Laptop to 3g router on a cat5 cable, then use 3 mobile internet to upload. All fo this will run on 12v if you wanted but this is dependent opn your laptop. I run it on 240v but this could be easilly remotly switched usoing GSM controls.
The webcam was about £30 as I recall.
My mate Paul has a much more 'ON' stream from his truck http://www.truckcam.tv/ using the same sort of equipment.
see in Ely, webcam live at :
Webcam Ely
WRONG Ely. Suspicious 1st post IMO.
Edited by Biggles
