stern gland
#1
Posted 27 April 2012 - 11:13 AM
15+years on the coast with stern drives though
4 years so far on the canals
1st 2 years on a boat that had water cooled stern gland??
But now have been told that everytime you run the engine with conventional stern gland,
you have to tweak the greaser every time you used the boat?
Is this right??
I ve got another small boat up for sale and twice ive seen the stern gland dripping, played with the greaser and it hasnt stoped, so booked a mate/engineer to repack it, he comes and its stopped!!!
PS Ive checked the boat this morning, and its still behaving it self
thick col
#2
Posted 27 April 2012 - 11:15 AM
Have been boating for years
Is this right??
thick col
I can't say if it's definitely correct practice BUT it is what we were always told as hireres and is something I've carried on ever since....I always get at least a turn or two.
#3
Posted 27 April 2012 - 11:34 AM
To be honest I do not always do it.
The procedure, I was told and do, is take up the 'slack' until pressure is felt then ½ to 1 turn and the job is done.
#4
Posted 27 April 2012 - 11:45 AM
Is this right??
The extent of my experience is not a patch on your but the first time I rented a boat I was told to turn the greaser until is felt slightly tighter, did is every morning when checking the weed hatch. I never sank but then again, neither did you.
thick col
Edited by Burgiesburnin, 27 April 2012 - 11:46 AM.
#5
Posted 27 April 2012 - 11:55 AM
Certainly so when I worked for a hire firm.
I'd suggest a degree of common sense is involved.
iI you just use the engine mildly, know the gland seldom drips, and will be boating again next day, I'd not be obsessed about it.
If you have slightly worn gear, or packing, and have been thrashing the living daylights out of it for hours, I think I'd definitely aim to do daily, simply to reduce any leakage there could be.
Back to OP, though, there is usually a half way house between "greaser not fully stopping drips", and "need to re-pack gland". They can of course also be adjusted, (usually by slightly tightening down a couple of nuts), so if "a bit of a turn on the greaser" doesn't totally stop the drips, that is the next thing to try. If kept propetly maintained, a full re-pack should be very rare indeed, unless it is a very high mileage boat.
#6
Posted 27 April 2012 - 12:04 PM
Exactly rightAt the end of the day, after using the boat, then a tweak of the greaser is a good idea.
A properly set up stern gland should never drip,the greaser is to lubricate the (usually) bronze bearing behind the packing
grease will act as a temporary method of stopping or slowing a drip.
#7
Posted 27 April 2012 - 12:06 PM
Is this right??
Yes, broadly speaking. But as Alan says, the next thing to try is to tighten the nuts on the two studs that keep the collar in place. This will compress the packing material a bit more.
By the way, are you the same poster as Big COL?
http://www.canalworld.net/forums/index.php?showuser=40
Just wondering.
Mike
#8
Posted 27 April 2012 - 12:08 PM
#9
Posted 27 April 2012 - 12:19 PM
Yes thanks for the replies, its all about knowing your stern gland
And yes theres 2 of us on the forum Big COL and then theirs me bigcol
thanks all
So what was the correct answer then???
Col
#10
Posted 27 April 2012 - 12:21 PM
Hi there all
Yes thanks for the replies, its all about knowing your stern gland![]()
thanks all
Col
Great, thats confusing then innit! Thanks for clarifying.
The correct answer is 'YES'
Mike
#11
Posted 27 April 2012 - 12:22 PM
#12
Posted 27 April 2012 - 01:25 PM
This problem was on a old life boat 1903 !!
I will try to take a pic and post it re the gland
My mate says hes never seen anything like it
I know the prop is inside a big steel substantial circilar protector tube
that turns with the prop when tiller is used??
Col
Edited by bigcol, 27 April 2012 - 01:27 PM.
#13
Posted 27 April 2012 - 01:27 PM
Exactly right
In 30 years of yachting, the consensus was that a manually greased stern gland should drip about once a minute, and should feel warm, but not hot, in use. The choice seemed to be "just dripping", or, "just not dripping". The former seemed easier to achieve than the latter where, if you tightened it to stop the dripping, it may be too tight, thus wearing the prop shaft.
I always felt more comfortable with a slow drip which, if it became a faster drip, suggested the gland needed either tightening, or repacking.
Now I have a supposed maintenance free gland, which makes me feel a bit uncomfortable
#14
Posted 27 April 2012 - 01:50 PM
The main job of the grease is not to keep the water out, that is the job of the packing. The grease is to reduce wear of the shaft. Not greasing it will increase the wear, causing more leakage and early failure of the stern gear and shaft. The grease is worked out of the tube by the rotating movement of the shaft, bit like the Archimedes Screw effect. Greasing the stern gear is important, and should be done frequently.
What he says. To keep the water out you tighten the flange. You give the greaser a turn for lubrication. The only times you use the greaser to stop a drip is 1. If the packing needs replacing or 2. The stern gland is worn. In both cases this is only a temporary measure until a proper repacking or repair is made.
Mind, I've been involved in old working boats where temporary was a loose term.
#15
Posted 27 April 2012 - 02:22 PM
Yes,the dripping gland is a common ocurrenceIn 30 years of yachting, the consensus was that a manually greased stern gland should drip about once a minute, and should feel warm, but not hot, in use. The choice seemed to be "just dripping", or, "just not dripping". The former seemed easier to achieve than the latter where, if you tightened it to stop the dripping, it may be too tight, thus wearing the prop shaft.
As i said before a correctly installed and maintained gland should NEVER drip,once bedded in and adjusted in the proper fashion
Maybe the drip makes yachties thirsty,so they turn the greaser a few times and depart to the nearest source of alcoholic beverages?
Edited by cereal tiller, 27 April 2012 - 02:23 PM.
#16
Posted 27 April 2012 - 03:10 PM
Actually that's a bit debatable. Certainly with older boats, the bearing was essentially water lubricated & the grease was mainly to lubricate the packing and keep the water out. Any grease finding its way into the bearing would be a bit of a bonus. Modern narrowboat sterngear has rather shorter bearings in relation to their length & grease is more important, but there must be quite a few out there where there's more water than grease.
Tim
#17
Posted 27 April 2012 - 03:22 PM
Have always considered the grease to present to lubricate the bearing and to keep the packing from becoming too waterloggedActually that's a bit debatable. Certainly with older boats, the bearing was essentially water lubricated & the grease was mainly to lubricate the packing and keep the water out. Any grease finding its way into the bearing would be a bit of a bonus. Modern narrowboat sterngear has rather shorter bearings in relation to their length & grease is more important, but there must be quite a few out there where there's more water than grease.
Tim
The greaser tube usually delivers the lubricant to the centre of the bearing,only a small amount is required to reduce wear.
any excess of grease should find it's way to the outside of the boat via the stern tube.
One common cause of rapid packing wear is the shaft moving back and fro,thrust bearings eliminate any linear movement.
#18
Posted 30 April 2012 - 10:39 PM
Good course and well worth attending.
#19
Posted 30 April 2012 - 10:57 PM
Tim
Water lubricates? That is a new one to me. Cooling perhaps, but lubricating..? And what kind of technolitgy relies on grease finding it's way to the bearing by change....
#20
Posted 30 April 2012 - 11:04 PM
Water definitely lubricates certain items.
When my yacht was out of the water in 2009, if I turned the prop, the cutlass bearing squeaked. Throwing a bucket of water along the shaft, and into the bearing, stopped the squeaking.
The grease is under pressure on the prop shaft. As tha shaft turns, the grease spreads around, and along, the shaft. Over time, as it spreads more thinly, the pressure reduces, and more grease is neaded, hence tightening the screw on the grease container.
Not a difficult concept.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
