Hi all, this is one of many question i`ll be putting on this forum, is it possible to cruise around the canal network and deal with lock by yourself, or does it require 2 people, i`m thinking ahead i wish to live on a boat but it will be by myself
Thanks for your help
susan
susan
yes and plenty of single handed females manage by themself...even women on fuel boats...practise/take your time/watch other solo boaters.....IM a single handed boater and manage find.........your find plenty of advice on here from the collective....
good luck............
Thanks for that i was worried about that bit, but you have put my mind to rest
Quick answer is yes. There's a book that's about going it alone (I think that may be the title!) which has some handy tips in it. I'll see if I can find link....
Edit to add: Believe this is the book: Colin Edmondson's Going it Alone - a boater's thoughts on single handed boating (don't have it myself, but it's been recommend here a few times) http://www.canaljunction.com/boat/singleorder.htm
Edited by Robbo
Single width locks are nice, wide locks need a bit of care, swing or lift bridges are a pain.
It's all do-able but sometimes you need to learn some tricks from those who've done it before, so you're wise to ask here.
Single-manning also slows you down at first, so add maybe 30% onto any journey plans from sites like CanalPlanAC. Experienced single boaters are another matter, I've followed individuals in the past and we've had a crew of 2 or 3 and struggled to keep up :)
Edited by sociable_hermit
I'd point out that it would help greatly to learn boating with a crew of at least two until you know how to handle boats and canal structures and be complete aware of all the problems that can befall you. You don't want to 'learn' when you are all alone and trapped in the middle of nowhere.
Good luck,
Mike
ps. for 'learn' read "have a major injury".
Waterways World magazine has an article for single handling in February's edition.
This thread contains relevant advice and comments about buoyancy aids, relevant to single manning on a canal boat.
Re the booklet, treat it as a 'thought provoker', not a bible. If you aren't sure of a suggestion, think up what you would do instead.
TBH, it's a bit chicken and egg, practicing as part of a double act is fine, but until you have done a bit of single manning you might not appreciate just what differences you have to work into your procedures, or your boat design / layout.
HTH
Edited by Davidss
I would commend a light line running along the roof from the stern, connected to a bowline/loop in the bow rope.
Very handy when using ladders to climb out of an empty lock - you just take the line with you and then do the awkward bit of pulling up a heavy bow rope when you are safely on the lockside.
You can see it in ready for use here and in action (sort of) here.
yeah, just read that. why oh why, tie the boat down in a narrow lock?? And bow and stern? Please ignore the advise from that article...
If you have a smaller than lock boat it is very useful to keep control of the boat especially if it's quite a violent lock.
yes, with the centre line. half turn round bollard if needed, always controlled, in the hand, by the boater. Tying boat down with two ropes is recipe for disaster.
I find the centre line never stops the boat from going forward or back enough as there's never a centre bollard in the right place. I don't tie, I use just wrap the rope around the bollard about 4 times. That way I can control both if needed from afar. I'm 50ft by 12ft, so on most locks I have width to control a well..
Surely being 'delicate' with the paddles would be a better idea?
Watch the boat and raise the paddles accordingly.
susan
Just relax and work safely. If you are alone at a lock you have all the time in the world. If others are queueing they will help you through or continue to queue, their choice.
George ex nb Alton retired
Edited by furnessvale
I'm on the Aire and Calder, our locks are automated, but I still find on manual locks it's better for me.
Edited by Robbo
I am glad I wasn't the only one to say that .
One method often used to keep the boat steady when locking uphill single-handed is to leave it in forward gear so the bow fender rides up the cill.
I wouldn't recommend that for newbies...
so......
how do you descend Bath deep lock with a 50 foot narrow boat single handed?
(I ask this as one who has been boating, often single handed for 20 years - I admit defeat to this one.)
not so. It is sufficient to run a line back from the bow with the boat as far forward as possible.
What's special about Bath deep lock?
Just Googled, it's similar to Lemonroyd lock, which I've done single handed (although I don't mind climbing ladders)..
Edited by Robbo
