luctor et emergo Posted April 29, 2013 Report Posted April 29, 2013 Yes, you can. You are declaring the intended use of the fuel you are buying. If you intend to use all of it for generating (heat and/or electric), than you can declare 100% domestic. Not everybody fills up a tank everytime. I had customers who would take maybe 20 liters, just so that they could keep the batteries charged and make hot water for a week or two. No moving of the boat in that time. You suggest they make a false declaration?
Steilsteven Posted May 1, 2013 Report Posted May 1, 2013 Yes, you can. You are declaring the intended use of the fuel you are buying. If you intend to use all of it for generating (heat and/or electric), than you can declare 100% domestic. Not everybody fills up a tank everytime. I had customers who would take maybe 20 liters, just so that they could keep the batteries charged and make hot water for a week or two. No moving of the boat in that time. You suggest they make a false declaration? OK, but sooner or later they'd have to declare some propulsion use whether the boat moved or not. Whereas a houseboat owner wouldn't. Keith
Paul C Posted May 1, 2013 Report Posted May 1, 2013 OK, but sooner or later they'd have to declare some propulsion use whether the boat moved or not. Whereas a houseboat owner wouldn't. Keith Yes but "sooner or later" is very different to "every time". And it doesn't need to be a houseboat mooring, any type of home mooring would do. The only one which wouldn't do, is the genuine CCer.
luctor et emergo Posted May 1, 2013 Report Posted May 1, 2013 OK, but sooner or later they'd have to declare some propulsion use whether the boat moved or not. Whereas a houseboat owner wouldn't. Keith Why should they declare propulsion if the boat hasn't moved?
ditchcrawler Posted May 1, 2013 Report Posted May 1, 2013 Why should they declare propulsion if the boat hasn't moved? Its just what the HMRC guidance said.
