RLWP Posted May 1, 2012 Report Posted May 1, 2012 <snip> Of course water would not be an adequate lubricant for internal combustion engines. Tim It may be OK if you wanted to try it. I seem to remember someone demonstrating running an engine and using Coca-Cola as a lubricant. It would work fine to produce the hydrodynamic wedge in the main bearings to hold the shaft off the shells. There are a few issues though to do with corrosion resistance, cooling of the pistons and evaporation. Richard
cereal tiller Posted May 1, 2012 Report Posted May 1, 2012 It may be OK if you wanted to try it. I seem to remember someone demonstrating running an engine and using Coca-Cola as a lubricant. It would work fine to produce the hydrodynamic wedge in the main bearings to hold the shaft off the shells. There are a few issues though to do with corrosion resistance, cooling of the pistons and evaporation. Richard Does the coca cola go 'flat' quicker than usual? Are the top up intervals longer with pepsi? Personally,i would prefer to use IRON-BRU!,obvious,really
